Introduction: Mini Hand Drill Machine
Hello friends, so in this instructable we are going to make a mini hand drill machine.
As the hand drill is very usefull in many diy projects so making it on your own is a fun way for a hobbist .
Hope you like it.
1. 1.5inch PVC pipe * 2 pieces
2. 555rpm DC motor
3. Connecting Wires
4. DC jack
5. Mini Drill Chuck kit
6. 12v Adapter
Step 1: Using PVC Pipes
1.Take the pvc pipes and join them using glue stick.
2. Mark on it so that it is easy to cut out that portion
Step 2: Placing the Motor
1. Place the motor inside the pvc pipe.
2. Do connections on its terminals
Step 3: Connecting DC Jack
1. Place a cardboard piece on another end
2. Place a DC jack on the that end
3. Connect those motor terminals to a DC jack.
Step 4: Connecting Drill Chuck
Connect the drill chuck over the rotor end using allen key
Step 5: Connecting Drill Bit
Connect the drill bit to chuck using chuck key
Step 6: Power Supply
Connect the 12v power supply to it and check the output result.
Step 7: Result
Check the video!
Thankyou.
