Introduction: Mini Knex Double Barrel Shotgun
About: I’ll be back making instructables soon, took a long break from doing these
Hello, I haven't posted anything knex in a while, so I decided to post this thing. I pretty much threw it together, so don't expect anything amazing.
Step 1: Barrel
Take a yellow rod. Put 6 red connectors all same orientation on it. Then put 2 yellow(same orientation as reds). Then put the trigger(orange connector with white rod and green rod on it) onto the rod, and 2 more yellow connectors. Repeat twice. Connect the 2 with green rods in back and front.
Step 2: Handle
.....um just look at the pic
Step 3: Handle + Barrel(s)
Use the little nubs of the yellow rods to connect the 2 green pieces on the handle to the barrel(s)
Step 4: Ram Rod(s)
.... so ez
Step 5: Rams + Barrels
put the rams in the holes and rubber band as shown
Step 6: Optional Little Things
Look at the pics(the first one forces you to fire both at once)
Step 7: Loading and Firing
Put 3 green rods in each barrel after pulling back ram, then push triggers away from centre to fire
