Introduction: Miss La Sen Vesak Lantern
On Vesak day, the lantern festival, people hang many lanterns to celebrate these important events.You can make yourself the glass paper lantern easily.
Step 1: Download This Pattern and Print It Out in A2 Size Paper for the Lantern Form.
Step 2: Download This Pattern for Miss La Sen Shape and Print It Out in A4 Size Paper.
Step 3: Use the Thick Foam, 5mm Thick to Have the Strong Base. Cut Out the 4 Squares With 2 Colors.
You can decide the colors.
Step 4: Cut the Body of the Lantern.
Step 5: Cut the Hole on the Foam Body to Glue the Glass Paper Later.
Step 6: Punch 2 Holes on the Top to Poke the Zinc String So That You Can Hold or Hang It
Step 7: Roll the Foam Body Into the Pipe Shape. Glue 2 Ends of the Shape.
Step 8: Cut 2 Parts to Poke on the Top and on the Bottom.
Step 9: Punch 4 Holes on the Body Pipe to Poke 4 Arrow Tabs Onto the Top.
Continue to make with the bottom.
Step 10: At the Top, You Punch a Hole to Insert the Small Electric Light.
Step 11: Poke 4 Squares Together Like That to Glue It Onto the Foam Body Pipe in the Center.
Step 12: Punch 2 Holes, One at the Top, One at the Bottom on Each Square to Poke the Arrow Tabs on the Body Pipe.
Step 13: Cut the Miss La Sen 's Head.
Step 14: Cut the Flower and Headband. Glue Them Like the Picture.
Step 15: Cut the Eyes, Mouth, Cheeks, Flower, Bow and Glue Them Like That.
Step 16: Glue the Head Onto the Dress.
Step 17: Cut the Arms and the Shoes
Step 18: Glue the Arms, Shoes Onto the Dress
Step 19: Glue Miss La Sen Onto the Lantern. Done
Punch 2 holes on the top to poke the zinc wire so that you can hold or hang it
