Introduction: Mobius LED Lantern
We describe how to build a color-changing lantern out of two interlocking mobius strips. The lantern will not illuminate your space enough to read by, but you will can use it as a decorative lighting feature to set the mood for parties or everyday.
Step 1: Collecting the Materials
You will need the following materials:
-- thick semi-translucent Mylar
-- transparent fishing line or string
-- tricolor LED, e.g. RGB-1WS
-- 10-100 ohm resistor (value varies, Resistor Calculator)
-- Arduino board (or other microcontroller) and USB cable for programming
-- battery (7.2V Li-Ion 6600 mAh)
Step 2: Programming the Microcontroller
Program your Arduino board using the attached code.
Note: You do not need to use an Arduino board, but you can use any other microcontroller.
Step 3: Preparing the Board
-- tape the battery pack to the underside of the board (make sure to insulate the battery)
-- tie fishing line to the three connector holes on the board
-- tie the three lines together in the center above the board
Step 4: Making the Housing
If you do not have access to a laser cutter, use the attached files in pdf format to print a template. Cut out the two strips of mylar.
If you have access to a laser cutter, download the attached dxf files and cut out the two strips of mylar.
Step 5: Assembling the Lantern
-- connect one mobius strip with the interlocking tabs
-- slide the second strip through the first strip and connect the tabs
-- punch a hole for the fishing line
-- slide the arduino into the center of the lantern
-- draw the string through the hole as the top and fasten with a tight knot
Step 6: Getting a Sense of Scale
In this image you can see approximately how big the lantern is and how it creates an ambient lighting effect. You can adjust the look of the lantern by wrapping the strips of mylar tighter (these are approximately 24"). The lamp shown in these images is 12" by 8".
Step 7: Enjoy Your Lantern
Congratulations -- you've built a color changing Mobius lantern! You can enhance this system by adding sensing or other lighting features.
