Model of Prokaryotic Bacteria - DC Motor Flagellum
Intro: Model of Prokaryotic Bacteria - DC Motor Flagellum
This project is for STEM students in Year 7 to learn about the structure of bacteria, how DC motors connect to electronic switches and batteries and practice some basic construction techniques using cardboard, tape, craft knives and soldering.
STEP 1: TinkerCAD Designs
I used TinkerCAD as a drawing tool before I build, so I have a better idea of what I'm trying to make. I have created a 3D Model with AA batteries, motor and switch spread around the body of the bacteria, so the weight is evenly distributed. I have based the shape of the bacteria on the prokaryotic cell shown in the videos linked above.
I have use the Circuit Design part of TinkerCAD to check that the circuit works before I attempt to create it IRL.
STEP 2: Making the Circuit
- I didn't want to buy anything for this project, so I decided to harvest some DC motors from an old useless computer. The DVD Drive yielded 3 different DC motors. I accidentally broke one of them straight away. Oops. I then connected wires to one of my batteries and tested the other two. The one that worked on 1.5 volts is the one I decided to use for this project.
- The old DVD drive also gave me some nice lightweight insulated wires to use. I attached these to the batteries using gaffer tape, because I didn't have a battery clip at the time. If you can get a battery clip you can skip a lot of finicky mucking around.
- Once I had wires attached to each battery, I soldered the circuit together in the same way as the TinkerCAD design from the previous step. When soldering little components I tape them down so they don't run away from me while I've got a soldering iron and solder in my hands.
STEP 3: Making the Body of the Bacteria
- I drew the shape of the bacteria onto some cardboard.
- I cut the shape using a craft knife. Be careful kids. Use scissors if you aren't able to use a craft knife.
- I had to improvise a bracket to hold the motor onto the body of the bacteria. This involved cutting a long cardboard strip and bending it around the body of the motor, and cutting a slot in the body of the bacteria.
- I used gaffer tape to hold together all the parts.
- I originally thought of using bambook skewers for legs, but these didn't work very well so I cut some wire from this old broken clothes hanger, which worked a lot better.
