Introduction: Modern Planter
In this Instrucatable, I am building a simple, yet modern, planter box.
Materials needed:
(1) 10-feet Cedar lumber
(1) Weed barrier
(1) Bag or river rocks
(3) Plants of choice (I used White African Iris)
(1) Bag of pot soil
- Outdoor Screws
- Outdoor wood glue
Check out my social media sites:
Instagram www.instagram.com/diycreators2015/
Facebook www.facebook.com/diycreators
Youtube: www.youtube.com/c/diycreators
Step 1: Cutting the Wood
Feel free to make this box as big or small as you like. The dimensions are below for this box.
After all the cutting, you should end with 9 pieces. (See below.)
The type of wood used for the project is Cedar.
Wood Dimensions:
(3) 7x30 inches = 2 long sides and bottoms
(2) 6 1/8 inches X 7 1/8 inches = 2 short sides
(4) 2 x 3 feet
Step 2: ​Assembling
When wood searching, try finding a good and flat lumber. I grabbed one that was a bit warped, and it was challenging to assemble. Using clamps helped hold the box together.
Since water will be constantly added, use screws that are made for outside application, such as those for wood fences and decks.
Adding wood glue would also help with the strength of the box.
Step 3: Prepping and Finishing
I applied an interior/exterior wood filler to cover the screw heads.
Sand the box down until smooth using 220-grit sandpaper.
Then apply the paint of choice. I used "Pure white High Gloss Latex."
Step 4: Attaching the Feet
Use an exterior wood glue for this application. You will also need to screw the feet on as well.
I used a combination square to keep the feet the same distance away from the edge.
Since I used wood glue only, masking tape was added to hold the feet in place as I put weight to hold it down.
Step 5: Adding Soil
Drill out two holes for drainage.
Install a weed barrier. This will also prevent the soil from falling through the drain holes.
I used garden soil, but I was informed that pot soil is better for this application.
Place enough soil to cover the entire bottom.
Step 6: Adding the Plants
Remove the plants from the pot and place in the box. Lightly loosen up the roots, but not too much.
Fold the weed barrier over as shown in the last picture. Then move on to the next step.
Step 7: Adding Rocks
Place the river rocks on top the of the weed barrier. Then do this all the way around, using the rocks to hide the soil and the weed barrier. Then, add water and you are done!
Youtube: www.facebook.com/diycreators
