Introduction: Money Inside a Brick Gift
This is money inside a brick.
This is a cool idea as a birthday gift
"Why are you giving me a brick?"
Could also be used to hide important things or may be a mystery/hunt type of activity for clues.
Wrap it up or tie a bow round it.
Step 1: Drilling the Hole
Mark roughly in the center of the brick.
Use masonry drill bits to drill the brick, I pre-drilled at 5.5mm and then used a 10mm drill bit.
As you'll see later in the video I should of drilled a deeper hole.
Probably need to drill about 2/3 of the way down.
Step 2: Place the Money in the Hole
Roll up and push it down the hole, may need to use a pen to help push it down but be careful.
Step 3: Fill the Hole
I used poly filler for the hole, and filler will do.
Don't shove to much in else it'll probably end up mixing up with the money.
I used the brick waste from drilling and sprinkled it on top of the filler for a more disguised look.
You could leave it white so it's more of a clue.
Step 4: The Fun Part.
Smash it!!
