Introduction: Monopoly Game Pieces With 3D Pen
Missing monopoly game pieces? then why not make some with your 3D pen! this is very simple and anyone can do it. it's failproof! and if you are not missing game pieces why not make some extra!
-3D pen
-white filament
-black filament
-any color of filament for your tokens
-red filament
-blue filament
Step 1: The Dice
3D pen a 1 1/2 cm cube with white filament. Then fill in the sides to make a box. use black filament to dot the numbers. then you are done with the dice.
Step 2: The Dice
3D pen a 2cm circle fill in the circle with green filament. then 3d pen a 2cm sick. attach the sick in the middle of the circle. make a line from the top of the sick to the bottom tip of the circle. push the line repeat until tent shape is formed. spiral the filament around the tent shape. spiral more around the top for the head. repeat until you have the amount you want.
Step 3: The Buildings
3D pen a 1cm square fill in the square with . make a 1/2 cm line on every corner of the square fill in. Now it should look like a square container. make another 1cm square. put a 1/2 cm sick midpoint of the top edge and midpoint of the bottom edge. make a line from the top of the sick to the bottom right corner of the square. then make a line from the top of the sick to the bottom left corner of the square. fill in to make a triangle.repat on the other side.fill in from the first triangle to the second triangle making a roof. Connect the roof to the square container. repeat until you have the amount you want. Repeat with red filament but insted of 1cm square use a 1 1/2 cm by 1cm rectangle. 1 cm in height. 1/2 cm roof height. repeat until you have the amount you want
Step 4: Have Fun!!!
