Introduction: Motorcycle Box
Been riding bikes for a long time and always been using racks and bungee straps when i have things to carry
seen plenty of top boxes and back boxes but they are alwasy very large and ugly
so thought id make my own
Step 1: Givi Rack
This is the givi mono rack from my bike
i never had the box to start with so building straight onto it
Step 2: Bosch Drill Box
got this drill box from my work as they were throwing it away
and that gave me the idea for the back box
its hard plastic and quite large it used to have 2 drills in it
and ive taken all the packing from the inside
Step 3: Bolts
to fix everyhing together
I used some m10 bolts
thick square washers
round thin washers
wing nuts
Step 4: Measureing Up
making sure both the box and the rack would be ok to fit together
the box overhangs it by quite a lot but thats ok with me
working out where there plactic box needs to be cut
Step 5: Cutting
after marking the bottom of the box where the clips are on the Givi rack
using a dremel with a cutting disc to cut along the marks to make holes in the right places
so that the box sits flat with the base of the rack
had to file the edges down to make sure the it was good
made a few mistakes with where the box lined up, so ended up with holes a little larger than originally planned
Step 6: Plate for Under the Givi Rack
using some scrap aliminum and some paper as a template
cut and filed down to shape
this plate fits inside the gaps in the Givi rack so thats bolts can fix the box in place
Step 7: Fitting Bolts
measuring out the center and an equil distance between where each bolt is going to fit in place
using a drill, make holes big enough to git m10 bolts through
Step 8: Holes in the Box
lining up the box and he plate thats been made for the rack
mark and drill out the same spaced holes on the box and maked sure
that they are big enough for the bolts
had to do a bot of extra fileing at this point to get everything lined up
Step 9: Supporting Plate
found another bit of scrap ali
and thought it best to add some extra support to the inside
so again marked the bolt holes and drilled through
got extra washers and wing nuts to fix everything in place
Step 10: Covering the Holes
as youve seen from the previous steps
I made a mess of cutting the right sized hole for the slots at the edge of the box
so i made some covers out of an old pair of working gloves
cut out a stencil of the rough shape I need and added a little more at the edge
then hot glued them in place after sanding the area to make sure they glue had a good contact surface
Step 11: Finished
once the box and the rack were bolted together just to make sure it was fitting
I had to take it apart to reattach the Givi rack to the bike
then bolt the box ontop
then thats it finished and inplace
its quite sturdy and stayed inplace, theres a little flex around the corners, but it should be ok
will do an update if it falls off and I loose all my things to tell you dont build it like I did
thanks for reading
