Introduction: Mp3 Flash Wallet
This wallet is a simple duck tape wallet that added to ( This is only a guide line meant to inspire others. Don't judge to harshly)
Step 1: Supplies
1 Roll of Duct Tape*
1 Led flash light like the one below ( anything will work but since I'm not the best with electronics I worked with this one)
1 Old playing card
1 Mp3 player (in Gel case)
1 Old playing card
- You could even add to an old duck tape wallet if you had a little duct tape
Step 2: Step One
Bring out your LED flash light and remove as much bulk as you can leaving some kind of cover on the front
Step 3: Step Two
Now create a duct tape bi-fold works best if your not familiar with duct tape ducktapeclub can help ( they give better instructions than I do ) When your making it size does'nt matter as long as its as long or longer than your MP3.
Step 4: Step Three
Tape Magnet to the inside of the wallet and then line up the light so that when the wallet is closed the light is off and when its open the light is on. ect, then make a pocket or tape the light in place
Step 5: Step Four
This step is to secure the I pod in place
"fold the playing card in half and cover it in duck tape and then tape the bottom of the card to the wallet then slide the I-pod on using the space between the case and the I pod to secure it and then use a small strip of tape to harness the I pod" (as pictured)
Step 6: Woot Woot Your Done!!!!
fill up your wallet and go have fun!!!!!!!!!!!!!!!!!!!
