Introduction: Multi-Patterned Lamp #HMS2018
Here’s a way to make a multi-patterned lamp
Step 1: Supplies & Materials
You will need a:
Cutter
Ruler
Pencil
Any cardboard
Light Bulb with socket chord
Hot Glue Gun (Optional) or Glue
Step 2: Make 4 Frames
You will need to make frames for the base of the lamp. Get a ruler and make a measurement that is 19cm. This will be your biggest frame. Make measurements going down by 2, which makes it 17cm etc. The smallest frame you will get is 3cm
Step 3: Cutting the Frames
After drawing the frames, you will have to take a cutter and start cutting the frame until you get 36 individual pieces.
Step 4: Constructing the Base
After getting all your pieces, take the four 19cm frames, and connect them together and glue them until you get a cube.
Step 5: Making Patterns
After making the cube, take the other pieces and make patterns. Even though I made the cube first, I am still able to make patterns on it.
Step 6: Put in the Light Bulb
After making the patterns, put the light bulb.
Step 7: Complete
Enjoy the shadows
