Introduction: Multiple Frame Card
This is a simple way to make interesting card easily.
Supplies:
Creating the Image:
Now you just have to simply tape or past your frames on your card. Use every other one so you have white spaces showing in between. I showed how you can use all of the pieces to make two cards easily. Now you can leave it as is or write a little message in the middle!
Done!
Supplies:
- Silhouette Cameo
- Black Paper
- White 4 x 5.5 Card (I got mine in a pack from Michaels that came with an equal number of envelopes)
- Glue or Sticky Squares
Creating the Image:
- To create your own design, first draw a rectangle that is the size of the front of your card. Mine was 4 inches by 5.5 inches.
- Choose a shape. I chose the "frame" from the library. This image had two lines to it, so I ungrouped the image and deleted point by point one of the frame, leaving me with one image.
- Make the image so each edge is about 1/4 of in inch from each edge of the rectangle.
- Simply copy and paste placing each image about 1/4 an inch in from the previous image.
- I created the image 5 times which is perfect if you want to use the outside rectangle. If you do not want to use the rectangle frame, repeat the image 6 times.
- Make sure all of the lines are cut lines and sent it to the silhouette.
Done!
