Introduction: NPN and PNP Checker
About: I am a student of BSCS but I'm interested in electronics that's why I would like to think about innovative ideas and try to build my ideas into reality and i also interested in making a robots. email id: degen…
Hello! friends
Welcome to my another rechargeable transistor tester. Today i'm gonna show you how to make your own transistor tester and how to fit into a earrings box just follow the steps.
So, let's get started.
Step 1: Circuit Diagram
With the help of this diagram we can build our own transistor tester project.
Step 2: Materials
You'll need
Resistors: 1k x 4 and one 2.2k
1n4007 diode
Female pin
Led's: red,yellow and green
3.7 volt battery
Veroboard (dotted)
Some npn and pnp transistors
Push button
8 pin base
Earrings small box
Mini drill
Hot glue
Step 3: Cutting
Take a piece of veroboard and cut it down according to the size of earrings box with the help of mini drill.
Step 4: Removing Sharp Edges
Remove the sharp edges and turned it into a round shape then it's look like this and easily fit into the box.
Step 5: Soldering Base
Take a base and soldering it carefully according to the diagram with the jumper wires.
Step 6: Making Circuit
Place the components on veroboard according to the diagram and soldering it and join the all connections of base with veroboard.
Step 7: Fitting
Make some holes according to your design and then take your all components and fit into the earrings box nicely. After all it's look like this.
Step 8: Plugging Chager
Plug your charger with you transistor tester project for charging. The red led is showing charger is plugged. Put the transistor taster in front of you and observe the left side of the 8 pin base in a column is NPN and the right side is for PNP. Same sequence for Left and right side of the base like this E,B,C,E (upward to downward) because some transistors have emitter,base,collecoter and some have emitter,collector and base. When you place a transistor at left side of the base which is NPN then green led is glow and when you put a trnasistor at right side of the base which is PNP then Yellow led is glow.
Now you are ready to use your transistor tester.
Step 9: Finish
It's rechargable and easy to pick and obeviously easy to use.
I hope you guys like it.
