Introduction: Nicole Beaded Ring
Ingredients:
- One 8-loop ring base
- 1 Swarovski rhinestone ball
- 24 metal spacer beads, 3 mm
- 24 inches Soft Flex beading wire to match spacer beads
Tools:
- Wire cutters
- 527 Glue
Click Here for a printable version of this tutorial
Tools:
- Wire cutters
- 527 Glue
Step 1: Attach Wire to Ring Base
Tie the Soft Flex beading wire onto loop C so that both ends are the same length.
Step 2: Attach Rhinestone Bead and Spacer Bead
Thread one end through the rhinestone bead and then through loop F. Feed 3 beads onto the wire and then pass it through loop B and C. Feed 3 beads onto the wire and pass it through loop G. Pull wire tightly as you work.
Step 3: Pass Wire Through F + 2 Beads to B, Through C + 2 Beads to G
Pass the wire through loop F and feed on 2 beads and pass it through loop B. Pass the Soft Flex through loop C and feed on 2 beads, then pass it through loop G.
Step 4: Continue to Thread on Beads
Pass the wire through loop F and E and feed on 3 beads, then pass it through loops A, B, C and D. Feed 3 beads on and pass the wire through loops H and G. Wire tightly as you work.
Step 5: Finish Threading Beads and Glue
Feed 1 bead onto the wire and feed it across the ring underneath the rhinestone bead. Feed 1 bead onto the wire and feed it back across underneath the rhinestone bead. Feed 3 beads onto the wire. Feed the wire back across the ring and feed 3 beads onto the wire. Bring both ends of the wire underneath the ring, pulling wire tightly, and knot together securely. Place a small drop of glue onto the knotted wire and trim closely.
