Introduction: No More Table Lamp!?
About: From a DIY enthusiast to a DIY gardener 🍓
Everybody who owns a table lamp will sure feel that sometime the lamp gets in a way because its add crowdness to your work place.
However,...
This instructable will show you how to remove your table lamp and replace with a LED strip light at your work table.
Step 1: What You'll Need
Parts :
  1. LED strip light (plug N play)
  2. A work table with an overhead cabinet
Completion Time : 20 minutes
Where to buy?
https://www.amazon.com/s/ref=nb_sb_ss_i_9_16?url=s...
Step 2: Before the Change
Here is my work table with the table lamp is on. I will change that in a moment.
Step 3: The Strip
Firstly, I unpack the LED strips.
In this 'ible, I'll just use two strips, few connectors, a jumper cable and an adapter.
Step 4: The Assembly
I join the strip with the connector so that its can connect to another strip (make sure the positive terminal is joined with the same positive terminal indicates on the each strip's end).
Step 5: The Jumper
A jumper cable can also be used to connect to another strip.
The triangle emboss on the jumper indicates the positive terminal.
Step 6: The Adapter
The adapter has the same head as the jumper, so the setup is the same as before.
Step 7: The Layout
I finished the setup of the strips and then installed its under the overhead cabinet.
Step 8: The Lighting
I switch on the light and confidently remove the table lamp out of sight.
My work table looks nice!
The light illuminate beautifully.
Step 9: The Comparison
Here the images before and after the installation of the LED strip light.
HAPPY MAKING!
Please don't forget to vote for me.
If you like this 'ible, then please click 'Favorite' and 'Share' with your friends,
Or,
If you've made this 'ible, then click 'I made It' to let me know,
Else,
If you have anything to improve this documentation, to suggest an idea of refinement, or to query then please leave a comment below, and I’ll reply as soon as possible.
And lastly,
Please do subscribe my channel for future projects’ notifications.
Thanks for giving an apt appraisal for my 'ible.
