Introduction: ORGANIZING LAMP
WE WILL LEARN TO MAKE AN ORGANIZING LAMP WITH EASY TO FIND MATERIALS OR THAT WE ALREADY HAVE AT HOME.
MACHINERY:
DRILL
CALADORA
DREMEL
SANDER
CAUTIN
MATERIALS:
WOOD
LIJAS
WELDING FOR CAUTIN
LED STRIP
DAMPER
MANCHA VARNISH
ISOLATED TAPE
WOOD SCREW
Step 1: CUT AND WELD
FIRST WE'LL CUT 2 WOODS OF 15 CM X 10 CM AND 1 WOOD OF 20 CM X 10 CM.
AFTER WE WILL BEGIN TO WELD ALL THE CONNECTIONS, THE CONNECTIONS OF THE WHITE CABLE ARE 2 THOSE TWO CABLES THERE IS TO BE WELDED WITH A BLACK CABLE, THEN WE WILL SOLD THE OTHER CABLE THAT IS ONLY THE RED WITH ANOTHER BLACK CABLE.
ALREADY HAVING EVERYTHING SOLDIER, WE WILL SOLD FOR THE LAST TIME THE TWO BLACK CABLES WITH THE OFFER.
Step 2: SANDING, MARKING AND CUTTING
ALREADY HAVING THE CUT WOODS, WE'LL BEGIN TO SAND ALL THE WOOD UNTIL YOU ARE LISA.
THEN WE'LL BEGIN TO MARK ONE OF THE 15 X 10 WOODS THAT DISTANCE WE WANT OUR LED STRIPS.
WHILE THE OTHER TABLE OF 20 X 10 WE'LL CUT IT BY HALF.
Step 3: CUTS AND MARKING
AFTER HAVING MARKED THE DISTANCE OF THE LEDS, WE'LL BEGIN TO CUT WITH THE DREMEL EVERYTHING WE MARKED.
WE'LL DO TWO HOLES WHERE THE LED STRIPS ARE GOING TO ENTER. THEN WE WILL BEGIN TO DRILL THE OTHER WOOD OF 15 X 10 WITH A DRILL AND A DRILL OF 5/16 OR 3/8 TO MAKE THE ORGANIZER.
FINISHING THE PREVIOUS, WE'LL MARK AND CUT IN ONE OF THE HALF OF THE WOOD 20 X 10 THE SPACE WHERE THE BATTERY OF THE LED BATTERY WILL BE PACKED, THE HOLES WE MADE TO ENTER THE LED STRIPS AND IN THE OTHER HALF WE'LL MARK THE OTHER HALF OF THE BOX OF THE BATTERIES AND THE OFFER.
Step 4: UNION AND FINISHES
WE WILL CONTINUE WITH THE UNION OF THE TWO WOODS OF 15 X 10 WITH ONE OF THE HALF OF THE WOOD OF 20 X 10.
THEN WE ARE GOING TO JOIN THE OTHER HALF OF THE 20 X 10 WOOD TO MAKE 4 PERFORATIONS WHERE WE GO TO METER WOOD SCREWS SO THAT WHEN THE BATTERIES ARE DRAINED WE CAN CHANGE AND CONTINUE USING THE LAMP.
Step 5: PAINTED AND FINAL
WE ALREADY HAVE EVERYTHING FOR THE LAST WE WILL GET ALL THE WIRING TOGETHER WITH THE LEDS INSTALLED AND EVERYTHING SEALED WITH THE PICKETS.
ALREADY HAVING THE PREVIOUS WE ARE GOING TO PROSECUTE WITH PAINTED WITH STAIN VARNISH OR ANOTHER TYPE OF PAINT.
AND THAT WOULD BE ALL!!!
LUCK WITH YOUR ORGANIZING LAMP !!! : D
