Introduction: OUT OF THE WORLD
About: Total Novice but Extremely Passionate
Creating an outer space desktop wallpaper using Canva.
Let's get started.
Smartphone/Computer/Tablets/other gadgets with good internet connection
Time and Patience
Enjoy creating
Step 1: Signup/Login
  • If you already have an account,you are welcome to skip this step
  • If not,create one here
    • Using Google account
    • Using Facebook
    • Using email and password
Step 2: Go to "Create a Design"
You will now presented with the following interface
Remember that you are creating your own design .
The steps are in no way the only way to follow but a guide for you to access it quickly.
So use your talents and apply them to get the desired output.
Good luck!!
Step 3: Select a Template
In the search bar type the keyword "space" which will present you with related templates to use.
Lets choose the 4th one.
Keep the text box position and the alignment unchanged .
Edit the text
Type: OUT OF THE WORLD
Add the 4th Font Combination and edit the text
For upper part:Capital letters
Type "An astronautical"
For lower part:
Type "Experience"
Then proceed
Step 4: Change the Background With an Image
Start by navigating to Photos
In the search bar type the keyword "space" which will present you with related images to use.
Pick one of your choice and proceed
P.S:- You can do this step after completing the next one
Step 5: Let's Custom Make a Design
The design will be created with items available for our use in the left hand panel.
Elements/shapes/frames/even upload your own image.
Elements used
  1. Astronaut
  2. Orbit
  3. Sun
  4. Earth & Rocket
  • Dimensions should be balanced with regards to the area that needs to be covered.
  • Crop and Flip features are present.
  • Alignment and Orientation of elements can be changed by using the top panel options just below the head bar.
  • Colors can be changed .
  • Adjust/Effects/Filter gives you more flexibility to personalize.
  • Transparency and Grouping features are also present.
Step 6: Adding the Elements
Navigate to the element section on the left hand panel and type space in the search box .
Incorporate the desired elements one-by-one .
Then proceed to the next step.
Step 7: Finishing Touches
Check the visibility,size and color of the font
Save the file by changing the filename.
Here we save it as OUT OF THE WORLD
Step 8: CONGRATULATIONS!!
You created an unique design .
Download/Share/Publish
There are plenty of options available.
Choose as you wish.
Save as .png image
Share to twitter
and more.
Step 9: Comment/Like/Download
A token of appreciation motivates us to create contents for all.
Bye!!
