Introduction: Oak and Walnut Tortilla Press
About: Hey! Welcome to my Instructables page! I love to create and make stuff and decided why not share to how to make them with everyone!
For a gift this holiday season I decided I wanted to make this oak and walnut tortilla press for my wife. She loves cooking and really wanted to pick one up, so I decided to hand make her one! It was a pretty easy build, spanning around a couple of days and I'm really happy how it turned out!
Step 1:
I started off making the bottom section and the lid of the tortilla press. The press is 10" x 10" so I first cut the two oak slabs that make up the bottom
Step 2:
and then I cut the oak and walnut strips that make up the lid.
Step 3:
I glued up the bottom section
Step 4:
and glued up a pattern like this for the lid.
Step 5:
After those dried I cut down a 6" walnut piece for the beam across the top of the lid
Step 6:
rounded out the top of it
Step 7:
I then equally spaced where I was going to drive in three 3/8" dowel supports to help strengthen the joint
Step 8:
I drilled out the holes on my drill press
Step 9:
and glued in the three dowels.
Step 10:
Next I cut out two 6" walnut strips and a 3" oak strip to start putting together the piece that holds up the handle.
Step 11:
I rounded off the top of the pieces
Step 12:
and cut out two 2" oak strips, round off their tops and glued them to the rest of the piece.
Step 13:
I attached this to the bottom slab of oak the same way I attached the 6" walnut beam to the lid from earlier. I drilled out three equally spaced holes
Step 14:
centered it in the middle of the tortilla press
Step 15:
and glued it to the bottom section.
Step 16:
After that dried, I cut, glued and hammered in three 1/2" dowels to help strengthen the joint.
Step 17:
Closer look.
Step 18:
Next I started on the handle, I cut out an 11" oak strip and another strip about half that size
Step 19:
and clamp them together.
Step 20:
After it dried up I placed it in my Jawhorse and molded it into shape.
Step 21:
To attach the handle I cut off a piece of a 1/4" steel pipe I had around
Step 22:
I drilled out 1/4" holes in the handle holder and the handle
Step 23:
and assembled the handle section.
Step 24:
I then drilled in halfway into the walnut slabs and put in 3/8" wooden dowel caps.
Step 25:
Closer look.
Step 26:
Next I began the attachment of the lid and bottom section of the tortilla press. I cut out and placed down two pieces of construction paper (roughly the thickness of a corn tortilla)
Step 27:
Closer look.
Step 28:
I put the 3" brass hinges in place and marked out the spots for the screws
Step 29:
Step 30:
and screwed the hinges into place
Step 31:
With all the assembly done I took some wax paper and some play-doh and took it for a test drive!
Step 32:
Then it was time to sand, sand, sand!
Step 33:
For some finishing touches I cut out a leather strip for the area where the oak handle rubs against the walnut beam on the lid.
Step 34:
Closer Look.
Step 35:
Closer look.
Step 36:
Then I added on some clear rubber feet to the bottom.
Step 37:
Finally I used some Food safe butcher block oil and finish and viola the tortilla press is complete!
Step 38:
Step 39:
Hope you like and thanks for checking it out!
