Introduction: Object Detection Using the HC-RS04 and Arduino
In this project, we will build an object detection system using the HC-SR04 ultrasonic sensor and an Arduino Uno. The system has a variety of practical uses, such as preventing theft, monitoring areas to detect pets or rodents, and much more.
Features:
  1. LCD Module: Displays messages as an object or intruder approaches.
  2. Buzzer: Provides an audible alert to notify the owner when an object is detected.
This tutorial will guide you through building this simple project in three easy steps.
Arduino Uno
HC-SR04 Ultrasonic Sensor
LCD Module
Passive Buzzer
Breadboard
Jumper Wires
Step 1: Setting Up and Testing Ultrasonic Sensor
The HC-SR04 ultrasonic sensor emits ultrasonic waves and measures the time it takes for the waves to bounce back from an object, allowing you to calculate the distance.
Connections:
  1. VCC to 5V on the Arduino
  2. GND to GND
  3. TRIG to digital pin 11
  4. ECHO to digital pin 12
Testing:
After wiring, upload the code below to test the sensor:
This code will display the distance to an object in the serial monitor. You can refer to this Complete Guide to Ultrasonic Sensors for further details on the sensor.
Step 2: Setting Up and Testing LCD Display
The LCD module will display messages when the ultrasonic sensor detects an object.
Connections:
Follow the connection instructions in the helloworld example.
Testing:
Arduino IDE comes with a built-in Liquid Crystal Library. To test the display:
  1. Go to File > Examples > LiquidCrystal > HelloWorld.
  2. Upload the code and confirm that the LCD displays the "Hello World" message.
Step 3: Bringing Everything Together
Now that we've tested both the ultrasonic sensor and the LCD, it's time to integrate everything.
Connect Components:
  1. The ultrasonic sensor will detect objects, and the LCD will display a message depending on the object's proximity.
  2. Add a passive buzzer to digital pin 4. When the distance is below a certain threshold, the buzzer will sound an alert.
Final Code:
Upload the arduino file below. You might have to change some connections based on the digital pins used. Here's a basic version of the final code:
