Introduction: Origami Flower
In this instructable, we will learn how to make an origami flower
Step 1: Products
You will need two colors of paper one for the flower and one for the leaves. you will also need a ruler and scissors. You will also need some tape.
Step 2: Step 1: Cutting the Paper
You will need to cut your paper into 3 1/4 inch square
Step 3: Step 2:
Fold the paper in half horizontally then unfold,
then fold the paper in half vertically and unfold again
Step 4: Step 3:
Fold each corner into the middle
Step 5: Step 4:
Fold each corner into the middle crease again
Step 6: Step 5:
Fold each corner into the middle crease again. You are working with a really small paper, these folds they might be difficult to make. If you need to press down over the folds with your fingernail to create the creases.
Step 7: Step 6:
Carefully start to fold back the first layer of the paper to form the petals on the rose. A soft crease will make it look more realistic
Step 8: Step 7:
Fold out the second layer to make more petals.
Step 9: Step 8:
Fold back the last layer to create the last of the petals.
Step 10: Step 9: Start the Leaves
Cut the green paper for the leaves into 3 1/4 inch squares.
Step 11: Step 10:
Fold one half of the square to make it look like like the picture.
Step 12: Step 11:
Fold the other side of the square in to make it look like a kite.
Step 13: Step 12:
Fold the widest point on one side to the middle
Step 14: Step 13:
Fold the other side of the widest point into the middle to make a diamond shape.
Step 15: Step 14:
Fold the diamond shape in half
Step 16: Step 15:
Take half of the triangle and make a squash fold on the right side by lifting up the paper and when it is the right shape shown above press down to create the squash fold.
Step 17: Step 16:
Repeat step 15 to the other side.
Step 18: Step 17:
Flip over the final product of the leaves
Step 19: Step 18: Finished!
glue the flower onto the leaves.
