Introduction: PLC Programming WPLSoft & ISPSoft Simulator
About: Experience sharing is better than giving advice
#WPLSoft & #ISPSoft simulator steps
#WPLSoft #ISPSoft #plc programming #simulator
Step 1: ISPSoft Simulator
ISPSoft simulator need to install COMMGR to run a simulator
1- open Commgr add driver (#DVP simulator) and start it follow image steps 1 to 5.
2 open ispsoft select communication settings from tools menu image step 6.
3 choose the driver name image step 7.
4 click on online mode then run step 8 then 9.
Step 2: WPLSoft Simulator
After programing you can simulate your program click on the below
simulator button 1 on image. to choose a simulator as a communication
Online mode button 2 on image. to start test and simulate your program
Step 3: WPLSoft Ladder Monitoring
to view the input output state you can select (ladder monitoring) or (stop ladder monitoring)
Step 4: WPLSoft Run Mode
to run the PLC and push an X0 input click the below
run button 3 on image. (put PlC ON Run Mode)
set on 4 on image. (active the input)
set off 5 on image. (de-active the input)
