Introduction: “PROSECCO SANTERO” WALL LAMP
How to transform a cardboard package with beautiful graphics (Santero) into a nice applique with LED lamp.
Reuse of Santero prosecco packaging; this work shows how we can easily and without special tools, recover a material that would otherwise be a waste.
The procedure shown in the photos, begins with cutting the cardboard according to a simple shape, then you have to puncture each strip of cardboard, with a little patience you can pass a thin wire in the holes, pulling slowly you will build the desired shape and the same wire can be used to block the lamp on the wall.
Obviously, being cardboard, you will have to use an LED bulb that does not heat up.
The edges of the cardboard cuts can be finished with a black marker which will make the perimeter cleaner; if the cutting is performed with a lasercut machine, the precision and the "cleaning" of the edges will be increased.
materials used: cardboard packaging (Prosecco Santero), wire, LED lamp
design by giovanni giobbi vona
link giobbi.it https://giobbi.it/lampada-applique-prosecco-santero/
Step 1: Cut
Step 2: The Holes
Step 3: Wire
Step 4: Lamp Led
and the same wire can be used to block the lamp on the wall...
