Introduction: PVC Bird House
FOR the bird house you will need 6 90 degree side outlet connectors, 6 TEE connectors, 2 elbow connectors, and 4 45 degree connectors. For icing you will need 2 7 inch pipes, 2 3 inch pipes, 4 4 inch pipes, 2 pipes the length of what you are going to hang the bird house on, 2 3.5 inch pipes, 4 3/4 inch pipes, 4 four inch pipes, and 1 three inch
Step 1: The Base
For the base of the structure you will need 2 seven inch pieces of PVC and 2 three inch pieces and 4 90 degree side outlet connectors. connect the pipes together so the create a rectangle
Step 2: Creating the Sides of the Bird House
For the sides of the bird house you will need 2 3.5 inch pipes and two 3 inch pieces. you will also need 2 TEE connectors. build up from the base. take the 2 3 inch pieces and put into the base. then have the two tee connectors on the top of the 3 inch pieces. then take the two 3.5 inch pieces and put them on the top of the Tee connectors.
Step 3: Other Side With Arms to Connect to Deck
For the other side you will need 2 3.5 inch pipes, Four 3/4 inch pipes, and 4 TEE connectors. take the 2 3 inch pipes and put them coming out of the base. then put the two tee connectors on top of the 3 inch pipes. then coming from the tee connectors have on 3/4 inch pipes and then put two more tee connectors and top of the 3/4 inch pipes. out of those tee connectors have two more 3/4 inch pipes
Step 4: The Arms
for the arm you will need to measure the with or the railing on your deck or where ever you are going to hang it. once measured cut two pieces of pipe the length that is needed. attach 90 degree connectors to the ends of two of the pipes. put the ends without the connectors on it into the TEE connectors.
Step 5: The Roof
for the roof you will need Four 45 degree connectors, two 90 degree side outlet connectors, 4 four inch pipes and one 3.5 inch pipe. take the four 40 degree connectors and place them on the top of the pipes that don't have anything on them. then take the 4 four inch pipes and put one in each 45 degree connector. connect the 4 inch pipes with a 90 degree side outlet connector. to finish the roof put the one 3.5 inch in to the connectors on the top
Step 6: The Walls.
For walls you can use any thing you want too. I used plastic bottles. Just get the material that you want for your walls and you attach it to the structure of the bird house you can drill holes and use zips ties to hold it in place. Just place the zip ties through the holes that you drilled and zip the ties.
