Introduction: PVC Snowboard Rail
The materials I used were five 2¨ by 4¨s and a PVC pipe that was almost 10 feet long. I also had to use a lot of screws as well as a screw gun.
Step 1: Step 1
We first had to measure exactly how long our PVC pipe was and then cut three of the 2¨ by 4¨s to that length.
Step 2: Step 2
Once I had them cut, I lined up two of the pieces and drilled them together.
Step 3: Step 3
Then I did the same on the other side with the leftover 2¨ by 4¨ causing it to look like this.
Step 4: Step 4
Then I cut out the legs for my rail which were only a couple of feet long but you can change the length of them depending on how tall you want the rail to be.
Step 5: Step 5
Then I drilled in the first leg which looked like this.
Step 6: Step 6
Once I had all of the legs in it looked like this.
Step 7: Final Step
Then all I had left was to put the PVC on top and drill in screws into it from the bottom and it was done.
Step 8: Final Product
This is what the rail looks like when it's all done and set up.
