Introduction: PVC Squirrel Feeder Windmill
Squirrels can be a real problem if you want to set out bird feeders in your backyard. They get into the feeders and chew them up to steal the seeds and also scare away the birds themselves. This instructable shows how you can solve this problem and have a fun time watching the squirrels on the rotating windmill as they try to get to the corn on the feeder.
All the materials are available at home centers or hardware stores for a total cost of about $15.00.
  • 60in. piece of 3/4in. PVC pipe cut into 4 15in. pieces
  • One 4 way PVC connector (3/4in.)
  • Four 3/4in. end caps
  • Four exterior grade wood screws at least 2in. long
  • One 1/4in. by 2in. brass nipple threaded on both ends (optional compression nuts)
  • One galvanized lag bolt (3in.) and two washers
  • A piece of Pressure Treated lumber to mount the feeder to
Step 1: Prepare the End Caps
Drill holes into the end caps and then insert the wood screws. Use screws that are threaded all the way to the head. The screws will be used to attach the feed corn to.
You can either glue the end caps to each of the four 15in. PVC pipe pieces or just push them on if they are a tight fit.
Step 2: Prepare Center Piece
Drill a hole through the 4way connector piece large enough to put the brass nipple through. The brass pipple is used because rotating on just bare plastic would soon wear out the 4 way connector.
Step 3: Assemble the Feeder
  • Take the 4 15in. pieces and glue them to the center piece with PVC cement.
  • Insert the brass niple through the center piece (if loose, you can add brass fittings on each end)
  • Mount the feeder onto a piece of Pressure Treated lumber using a lag bolt and two washers
  • Test to make sure that the feeder/windmill rotates freely
  • Mount the assembly outside near your bird feeders
  • Enjoy the fun of watching the squirrels go for the corn on the ends of the windmill
