Introduction: Panda Keychains
About: do androids dream of electric sheep?
A simple Panda Keychains made on a piece of waste plastic with cnc.
ONLY 8 Minutes! :D
Download project here
Step 1: Make Your Design
I chose this to start with, then I created the outline with the hole
Step 2: A Quick Check
Before starting it is always better to check how the CNC will behave
Step 3: Here Is the Result
When the piece is ready, use the acrylic varnish to paint the entire surface.
Acrylic varnish dries in 10 minutes but waits for one hour for safety.
Then you can use the sandpaper to remove the paint. I suggest you go to the largest grain (type 80), then go up to 180.
Only the outside paint will be removed, so the paint inside will remain!!! ;D
Now you can wash the Keychains with soap and water. Don't worry, acrylic varnish is waterproof.
Step 4: Final Result
Just I finished, it was stolen from a friend!
O_o
