Introduction: Paper Tower Storage
This tower can be used for a verity of thing it can be a small storage for little item’s shuck as beads or earrings. The use of it is up to you to decide anyway let’s start.
You Will Need:
- 3 A4 Sheets of paper
- A Ruler
- Scissors
- Pen or Pencil
- Sticky tape
Step 1: Making the Tower
This part is quick and easy. Simply fold an A4 sheet of paper in half then again and then again unfold it. It should then look like the first image above. Then you must fold it back and forth using a mountain fold then a valley fold and so on along those the creases so it looks like image 4 above. Then fold it alternating between 90degree and 180degree folds. It should now look a bit like image 5. Tape the at the top and bottom of each of the edges where the 2 layers of paper meet.
Step 2: Make the Levels
All you need to do here is copy from the image above each edge is 10cm and the dotted lines are one cm in from the out side. Dotted lines mean fold and solid lines mean cut. Fold the edges up so that it looks like a Shallow tray then tape the edges. Finally solid on the tray onto the tower. Repeat this five times and your done if you want you can create a outside to co
