Introduction: Paracord Bracelet Instructions
Easy Paracord Bracelet Instructions with Pictures. You will need about 12 feet of 550 Paracord, a Paracord buckle, a lighter and some scissors. If you want to make a 2 color paracord bracelet, melt the two ends of the paracord together.
Step 1: Paracord Bracelet Instructions - 1
Find the middle of the paracord, and attach it to the paracord buckles. Clip the buckles together and measure it on your wrist.
Step 2: Paracord Bracelet Instructions - 2
Bring the color of Paracord, you want to be the center color, across the paracord braclet like in the picture below. Then take the second piece of paracord, go over the top of the first piece, around the back, and up through the hole made by the first piece of paracord. Then pull both ends tight.
Step 3: Paracord Bracelet Instructions - 3
Now put the first piece of paracord, the center color, across the bracelet. Then with the second piece of paracord, go over the top, around the back and up through the hole made by the first piece of paracord.
Step 4: Paracord Bracelet Instructions - 4
Continue the braid, lay the first piece of paracord across. The with the second piece of paracord, go over the top, around the back and up through the hole made by the first. Keep braiding until you reach the other buckle.
Step 5: Paracord Bracelet Instructions - 5
Make sure you pull each knot tight, and evenly. Once you braided to the other buckle, cut the left over paracord off as close to the paracord bracelet as possible, then melt them with a lighter. Now your Paracord Bracelet is complete!
See the Viper Paracord Bracelet, or try these other Paracord Projects.
Sources:
ParacordTime.com
ParacordBands.com
