Introduction: Paracord Dog Collar
Have you ever wanted a unique dog collar? Well now you can make one.
Step 1: Supplies
- lighter
- scissors
- a permanent ink pen
- pliers
- tape measure
- painter's tape
- a loop to hold the dog tag
- a small buckle
- two different colors of paracord
- you also need to know how to burn the tips of cord
Step 2: Measuring
Measure your Dog's neck
Your Dog's Neck will be X, The length of the cord required will be Y.
Xft.+ 2in.+ (Xin.+ Xin.) = Y
Divide Y in half that is how long each piece of cord will be.
After each cord is cut remember to burn the tip.
Step 3: Starting
Wrap the two cords around the buckle and tape it. After you do that, you will need to wrap the cord on the right under the two cords
Step 4: Continuing
Continue weaving the cord until you reach the middle of the collar.
Step 5: Middle
By now you should've reached the middle and that means adding the dog tag. When weaving pull on one of the cords to make the loop bigger.
Step 6: Ending
Hopefully you've reached this point and now you can finish the project. Continue weaving over the taped cords. When you reach the end, move one of the cords to the side with the other cord and burn them together. Also remember to vote for this instructable.
