Introduction: Paracord Monster Cobra
About: Every one go follow us on instagram @theparacorders to see more
Step 1: Supplies
Cut 12-13 feet of cord three colors I'm using two strands of blue and one grey it doesn't matter if you have two grey and one blue either way it works. Depending on wrist size the one I'm doing is for a 8" wrist. You'll need •Scissors •Lighter •Buckle Jig (not required)
Step 2: Attach Both Colors to Your Buckle
I'm using a 5/8 buckle in this instruct able which is better for larger bracelets but you can use whatever size you want.
Step 3: Adding the Other Color
Find the middle of your grey
Step 4: Add the Grey
Step 5: Forming the Weave
Bring the right side across the top. Then bring the left side across that.
Step 6: Forming the Weave
Now run the left side under and through the hole. Keep the top color that you want in the middle on top of the other color.
Step 7: Tighten
Now pull it tight and make sure to keep the cords on the side from overlapping.
Step 8: Repeat
Repeat all the way to the bottom. Until you reach the end make sure to keep your cords straight.
Step 9: Making Your Way Down
Step 10: You've Reached the End!!!
Now that you've reached the end the next step is to cut and burn.
Step 11: Cut
Step 12: Burn
Step 13: Done!!!
You now have a finished monster cobra!!! That's packed full of cord for any survival situation!!!
