Introduction: Parametric Fashion Element
About: An Architect who loves building stuff!!
This is an experimental design project where you can either follow these steps to create a design, use this example as-is, or explore different possibilities. It's important to note that sometimes your efforts will succeed, and other times you may need to backtrack and try different approaches.
Paper
Scissors or cutter
Glue or stapler
Pins
Model to put it on
Step 1: Component Development
The first step is to create the component following the steps shown in the picture. It's a complex component, made by joining 2 components.
Alternatively , you can use a pre-made component such as a cone, straw, or a simple square of paper. The simpler the component, the easier it will be to work with during the proliferation process.
Step 2: Production
Make multiple components.
Step 3: Proliferation
Join the components. Experiment to join components in different ways. Or like in the picture.
Step 4: Final Planning
After understanding how the components come together to shape the form, proceed to plan your final piece.
Here's my plan.
Step 5: Final Product
Join the components as per plan. And done. Enjoy your product. You can use this as sleeves or a neck line or scarf. You can also make this using felt or some stiffer material.
