Introduction: Peace Box
This is called the peace box; the peace box is a cool hanging shoe box that us decorated and made to fit your personality! Have fun!
Step 1: Things You'll Need
You will need four clothes pins,a shoe box, tape( scotch tape is best), and sequins and other little treasures you can find. Then you will need a four inch cap (better if its clear)and that's all you need!
Step 2: Step 2
Ok so now you get your cap and decorate it with sequins and other little things then put them down with glue or if tape works you can use that. So that's step 2
Step 3: Aaa! the End Is Coming!!!
So now that you are warned that the end is coming we better hurry to finish this craft. So now take the string and cut four pieces that are the same length then take four close pins and put the string through the middle part that is a swirl then tie a double knot and do that 4 times on each corner. Then you find a place to hang it and if the string isn't long enough just tie more string to the top. And no you're done!!!
