Introduction: Pencil Sharpening's Pot
I go to The Forest School Horsham
When I started going back to school, I had to do lots diagrams in pencil which is annoying because it means that I always have to have a sharp pencil with me or sharpen one.
Whenever you sharpen a pencil, the sharpening's go everywhere so I decided to make something that stops this from happening.
All you have to do is put the pencil sharpener in place and put the top on and you will never get pencil sharpening all over the place again
For this you will need:
A 3D printer
Filament
Pencil sharpener
Pencil
Fusion 360
Step 1: Modify the Size of the Opening
Most pencil sharpeners are a similar size, but it is always best to check.
The one that I used is around 10x15 at the top, 5x15 at the bottom and 25 cm tall.
If yours is very different you can change the size of sketch nine for the top, sketch ten for the bottom and plane 4 for height. It is important to leave some clearance. I found a that making it bigger by the same amount as the layer height that you are printing with. For example, I used 0.28mm so I made the hole for the sharpener bigger by 0.28mm (0.14mm on both sides).
Step 2: Print the Parts
This step is pretty self-explanatory all you need to do is put the models in a slicing software and then print it. The thread works best if it has supports (I learnt this the hard way).
Step 3: Assemble the Top Half
Step 4: Screw Both Half’s Together
Screw the two pieces together and then you are done!
