Introduction: Pet Preparedness
Step 1: Items Needed
You will need to get a duffle bag or a large sturdy bag. You will also need a luggage tag or some form of a tag that will stay on the kennel. Pack with what your pet will need. I would pack the following items:
Food, with can opener, if needed (These are not pictured here)
Hand Sanitizer (a special bottle for here)
Bowls Water (not pictured)
Treats Catnip
Litter box Litter and scoop
List of other things to grab (see below)
Paper Towels and Wet Wipes (for any messes)
Bath towels (optional)
Any copies of vet records you may have and extra copies of your pet's prescriptions
Step 2: Label Your Kennel and Bag
The carrier/kennel you will be using should be stored right beside the bag, or if it will fit, inside. You could also attach the carrier handle to the duffel bag handle. Just make sure they go together.
A label on the carrier should include your name, address and at least two contact numbers. One should be yours and one should be from someone out of the immediate area that could provide information about the pet. Also, include the pet’s name and vet’s name and number. It is important that you list any medical condition or medicines given along with times and dosage. Make sure your animal’s shots are up to date at all times and the rabies tag is on the collar.
You could use a luggage tag, as I have, or just a piece of paper securely taped to the kennel.
Step 3: Make a Grab List
One of the best ways to determine what you will need is to go through your day to day routine. Place items in the bag if you have extras, if not, put it on your grab list.
After packing it all up, you can see that this will save you so much time.
Step 4: Notes
If you might be using a different vehicle, do a dry run pack on that vehicle also.
