Piezoelectric Generator
niravpatele63 'profile picture'
51K14138
Intro: Piezoelectric Generator
hello frnd,
i come with new attractive ,easy and smart power generation idea which is useful for your smart project and give new way of creation .
piezo electric power generation which is fully depend on applying pressure on piezo transducer,
STEP 1: Collect Wooden Plywood As U Want to Make in Your Size
cut as per images .
STEP 2: Buy Piezo Electric Buzzer at 20 Rs Per Pic and Modify As Image and Get Piezo Transducer
s
STEP 3: Draw Square Box to Attach Use Box As Per Show Images,,, Buzzer Upper Parts Use for Making Top Part to Press
STEP 4: Make Series Connection of Piezo Transducer
STEP 5: Finally Glue or (use Plastic Tap )on Series Connection on Down Part As Shown Image
STEP 6: Start to Generate Electricity by Applying Finger Pressure ,,,
STEP 7: Generate Electricity While Walking Homemade
26 Comments
Where are you using the peizoelectric buzzer
I want to make 12 v and 1amp piezoelectric generator so how much piezo required for this task?
I need to know how to make an power generator by foot steps And i need more brief explanation about project
Hi! My team has a project which needs this, and we were very happy to find your post! THANK you, by the way! BUT our project is focused on generating the electro energy from the mechanic, and we hope the Piezo will have a role of the "thing" that would accept the kinetic energy that is released after pushing a pressure on it. Is it so? Or is it just a kind of button? THANK YOU!!!
Plz tell me how to measure presurre in piezoelectric project
Connect them to a breadboard, make a rectifier bridge (using diodes), add a 25v capacitor, and it becomes DC. easier to work with and measure.
https://youtu.be/6_-n_DSJNFk?list=PL8PXGEvouIcx-wIh1S-qO2SrMwKiTOQZv
I dont know, but you can check voltage when you pressure that show how much voltage can be generated , thanks
from where I can buy piezoelectric disc at 20rs per piece...
actualluy i brought up bazzers ..get sensor into det ..
i took it out from buzzer . as per buzzer price it was consider .
Hello, I have a question concerning the piezoelectric devices used in this project. As it turns out I will be needing a piezoelectric generator circuit. The idea is that the piezos will charge moderately large capacitors which will then be dumped into a battery with some extra timing circuitry. However, I have not developed a circuit yet because the rochelle salt crystals I tried to grow were unsuccessful. So, instead of wasting my time, I went to Amazon and bought some piezoelectric elements marketed as guitar pickups/drum triggers. Will these work?
sorry ,i never used piezoelectric elements from things that u considered . i got piezo elements from buzzer . but that should be worked ..
Hello Nirav Patele. This is Preetham...I want an indetail information about this Project...I want to make this Project...Please send me information...My email: preethamsudhansh@gmail.com....Please send me indetail info about this...Please..It's a request...
Sir as I can see there is three wire one is connected to feedback part another connected to metal part and last one is connected beside the feedback part . So at the end we can see two wires make connection finally but third one is still unconnected...so why we are using the third wire which is beside the feedback path.??
i m not sure . but that is ground wire.
n Spain there is a small company that manufactures electric generators obelisk-shaped piezoelectric operating with a base and the movement of wind, thus avoiding the huge blades of the wind turbines that threaten the birds' migration routes. a larger obelisk captures more wind and produce more energy. for now they are struggling to break through against traditional energy production system and the pro-establishment
More Comments
