Plane Your Wood Slabs With a Planing Sled That You Build
Intro: Plane Your Wood Slabs With a Planing Sled That You Build
This instructable gives an overview of how to plane your wood slabs flat using a router and a Planing sled.
STEP 1: Start With Your Wood Slabs.
Here are the two wood slabs that I want to plane flat
STEP 2: Measure Your Wood Slabs Maximum Width and Length.
These wood slabs are on the smallish side. So I wanted to plane them together and match up the thicknesses. I figured I would make a planing sled that accommodates one large slab.
Measure the maximum width of the slab and the maximum length of the two slabs together.
I came up with 19" x 65"
STEP 3: Figure Out the Maximum Thickness of the Slab
Now find the maximum thickness of the slab.
You can now design your sled to accommodate for this.
(I noticed after making this Instructable that most slabs are 4" or less in thickness.)
STEP 4: Measure Your Router and Router Bit.
Measure the diameter of your routers base, and the diameter of the router bit that you will be using.
This determines the inside dimensions of your router sled and the hole that the router bit fits into.
My router base was 5 3/4" and the router bit was 1 1/4 ".
STEP 5: Construct Your Sled
Take your dimensions of your router and bit and apply it to your sleds dimensions. The router base was 5 3/4" so I made the inside width of the sled 5 7/8" The router will fit into this with an offset of 1/8". I also made the hole for the router bit 1 1/2" wide.
STEP 6: The Sled Assembled
Here is a photo of the sled. The first photo is the sled upright and the second photo is the sled flipped over. The sled has a flat base except for the two overhangs. This keeps the sled aligned on the rails while you slide it laterally.
STEP 7: Build the Box With Rails.
Take your maximum width and length of your wood slabs and basically build a box for it. The rails must be parallel and square. this is the reference for the sled. Also make the rails tall enough to accommodate the maximum thickness of the wood, in this case 4 inches, plus the thickness of the sled which is 3/4 inches, plus another 3/4 inches of "air" for your safety plane.
STEP 8: The Sled Base, Sled and Router.
here are photos of the sled base, which you will drop your wood slab into, the sled atop the rails, and the router placed into the sled.
STEP 9: Place Your Slabs Into the Sled Base
this is what it looks like after I place the slabs of wood into the sled base.
If the bottom of your wood slabs do not lay flat in your sled base, you can use shims and wedges so that they don't rock.
the final step is adjust the router bits dept so that i barely touches the highest point of the slab. You want to take off about 1/16" of wood at a time.
STEP 10: A Little at a Time
you can see how much wood I take off for each pass.
STEP 11: Start Planing
Start planing on one side and work you way to the other side. back and forth, right to left or vice versa.
and always wear your Personal Protective Equipment! PPE's
Preserve your eyes, ears and lungs!
STEP 12: Heres the Planed Surface
And here is a photo of the planed surface. its now perfectly flat and now needs a sanding in the direction of the grain.
35 Comments
matthewjperez76 4 years ago
justmetmc 4 years ago
PawełS4 9 years ago
Does anyone have an idea on how to add adjustable height to it? Preferrably without making new frame for each wood slab :)
Rio Vista Andy 4 years ago
klfuji 5 years ago
BrentM26 8 years ago
I got around this using Bench Cookies (any similar product either store bought or homemade would work as well). I had a slab that was too large for the sidewalls on my rig, so I drilled some holes into my work surface and added some threaded plugs (You could use hanger bolts, but you wouldn't have as many height options with that approach). I then added threaded dowels and used them to mount and elevate the bench cookies to a uniform height and placed the rig's frame on top of the bench cookies ( I used 12 to ensure uniform support).
robot-six 9 years ago
PawelS4,
Your hand router has an adjustment for your bit height. Therefore you do not need a new frame for each slab.
...Robot-Six
djculver 6 years ago
Fantastic instructable! Can you explain what you mean by "The router will fit into this with an offset of 1/8"? Usually, an offset is used when calculating the diameter of a guide bushing? I see no mention of a guide bushing being used here? It would make perfect sense to use a guide bushing to follow your track though!
robot-six 6 years ago
that’s the amount of distance or play between the inside edge of the planing sled and the outer edge of the router base.
itsmescotty 9 years ago
Not to detract from the author's accomplishment, I made something similar using inexpensive linear bearings and guide rails from ebay. I had a 6" slab from a 30" stump. No way was I going to hand plane or belt sand both sides of this slab. I incorporated a positive stop on the longitudinal slide so the router didn't go wandering about as I cut thru the annular rings. I used a carbide cutter and as the author I made minuscule cuts to lessen the impact on the router when encountering the high areas. I actually started out using a tool steel fly cutter. The wood rapidly dulled the cutter bit and I was forever sharpening it. That's when I moved onto carbide.
ShaunHill 7 years ago
Instructable please.
Kcb3rd 7 years ago
paolobertoncin 8 years ago
Great job make me one as soon as possible!
Baccawilly 8 years ago
Can you tell me what bit you're using?I'm going to make this soon
timbmac 8 years ago
Did you build two sleds for the router? If so, why two?
GreenAvenger 9 years ago
Spike63 9 years ago
Just a thought on this great Sled.
It should be possible to use an electric planer and adjust the sled making part to fit? You could still adjust the planer from above and take thin slices. I'll have to work on that one when my workshop's finished.
Spike63 9 years ago
Regarding movement of the slabs, you could hammer in pin tacks from above and then snip them off with a pair of wire cutters, they will then protrude about 1/16th of an inch above the floor of the sled, giving you almost no scarring, and no holes, on the underside of your slab. Great 'ible too, by the way!
avocadostains 9 years ago
A very interesting adaptive approach to planer. I dont know if you have seen for sale the electric hand planers. Here's an example: http://www.harborfreight.com/3-14-in-75-amp-heavy-duty-electric-planer-with-dust-bag-61687.html I used one to roughly plane an entire room of wood floor. It takes off a wide strip at a time but without some type of jig the total planed surface will not be perfect. The router planer gives very impressive results. If I could figure it out I would try making a simillar sled for my electric hand planer.
amclaussen 9 years ago
I had to refurbish four bedroom floors, and after doing some tests on their closet floor (that have the same wood), I ended up doing only one bedroom with a variable speed belt sander, 3"X21"... While doable, it was slow and tiresome, but the results were very good. Then I rented a profesional belt sander (a HUGE one, that has a 12" wide belt and weights 75 Kilograms!). I spent about a fifth of the time that I would have needed if Ihad insisted in using my hand belt sander, and it was way easier because this large machine has a large handle bar that allows you to push the machine when walking across the room, avoiding the need to be on your knees as with the hand belt sander. In any case, a belt sander gets a much better leveling compared to a planer when the surface is large, like a floor of an entire room. Amclaussen.
