Introduction: Playing With Lenses #phablabs
Discover, measure, have fun and play with light and photonics! Make a small kit with laser-cut and Plexiglas to experiment and play with the strange properties of light, from refraction to total reflection, from lenses to prisms, and play with the photonics billiards.
Properties of this workshop:
Timeplanning: Total: 2,5h
1. Familiarizing with optics and photonics: 60 minutes
2. Fabricating the kit and playing with lenses: 60 minutes
Target audience: Students (15-18 years old)
Estimated cost: € 12
DISCLAIMER: By using this information you agree to be legally bound by these terms, which shall take effect immediately on your first use of the information. PHABLABS 4.0 consortium and its member organizations give no warranty that the provided information is accurate, up-to-date or complete. You are responsible for independently verifying the information. VUB cannot be held liable for any loss or damage that may arise directly or indirectly from the use of or reliance on the information and/or products provided. PHABLABS 4.0 consortium and its member organizations disclaim all responsibility to the maximum extent possible under applicable laws: All express or implied warranties in relation to the information and your use of it are excluded. All liability, including for negligence, to you arising directly or indirectly in connection with the information or from your use of it is excluded. This instruction is published under the Creative Commons licence CC-BY-NC.
Step 1: Reflection and Refraction of Light
The speed of light
The light propagates in vacuum at the constant speed of c = 299 792 458 m/s (generally approximated at c ≈ 300 000 000 m/s). This means that a ray of light takes only a little more than one second to travel from Earth to Moon.
According to relativity nothing can move faster than light in vacuum. But in other transparent media the light travels at slower speeds, for example in water the speed of light is about vwater ≈ 225 407 000 m/s, in glass vglass ≈ 197 231 000 m/s, in plexiglass vplexy ≈ 201 203 000 m/s.
The refractive index
The ratio between the speed of light in vacuum and in a different medium is called refractive index. This number indicates how much the light is slower in the considered medium with respect to the vacuum. For example, the refractive index in water is nwater = c/vwater ≈ 1.33, in glass nglass = c/vglass ≈ 1.52, in plexiglass nplexy = c/vplexy ≈ 1.49.
Reflection and refraction
In crossing the boundary surface between two transparent materials with different refractive index a ray of light is subject to reflection and refraction:
(a) Reflection: part of the light is reflected back, with a reflection angle β identical to the angle of incidence α (see photo 1); alpha = beta
(b) Refraction: part of the light crosses the boundary and it is deviated, with a final refraction angle γ (see the figure below) related to the incident angle α by the "Snell law": sin alpha/sin gamma = n2/n1
Photo 2: This effect can be observed, for example, with pencil immersed in water that appears to be "broken" because of the refraction between water and air.
Explaining refraction
Refraction is due to the variation of the speed of light in the passage between the two media. Just to give an intuitive illustration, imagine light as a military column marching lined up by rows. When the soldiers enter in the region where they must slow down, they deviate from the original direction in order to maintain the line with their faster comrades (see photo 3). In a similar way a tank turns by slowing down one track with respect to the other.
Lenses
The deflection of light rays thanks to refraction is the basic concept for the manufacturing of lenses, fundamental elements for a large number of applications: eyeglasses, photo and video cameras, microscopes, telescopes, laser cutting, but also eyes and eyesight etc.
In the following scheme (photo 4) it is illustrated the working principle of a biconvex lens, capable to concentrate parallel light rays into a focus point.
Parallel rays coming from infinity and perpendicular to the lens (for example from a laser or from the sunshine) are concentrated at a distance F (focal length) from the lens. For any lens the focal length F is given by the formula in photo 5. (n = refractive index of the lens material, R1 = the radius of curvature (with sign) of the lens surface closer to the light source, R2 = radius of curvature (with sign) of the lens surface farther from the light source, d = the thickness of the lens)
Photo 6 shows different kind of lenses.
Total internal reflection
The total internal reflection is an interesting phenomenon related to the crossing of light between different transparent media.
In the passage from higher to lower refractive index (for example from water to air) a light ray diverges (see photo 7).
There is a limit condition for which the emerging refraction angle is parallel to the border surface (γ = 90°), and this corresponds to a limit incident angle alpha(L)=arcsin (n1/n2). For alpha>alpha(L) all the incident light is totally reflected back.
This phenomenon can be experimented underwater by observing the reflection of the seabed looking at the surface of the water (see photo 8).
Optical fibers
Nowadays fastest communications (telephones, internet etc.) are guaranteed by optical fibers. Optical fibers are essentially flexible glass wires within which the light is transmitted by total internal reflection. Photo 9
Step 2: Part List
Photonics parts:
*A eye-safe Laser module (Power < 1mW)
Other parts:
*Plexiglass sheet for laser cutter (5mm thick, 15cm x 10cm)
*Plywood sheet for laser cutter (4mm thick, 16cm x 21cm)
*1 9V battery
*2 rubber bands
Tools (for example in Fab Labs):
*Laser cutter
Don't find the material you are looking for? Via this link you could buy all the photonics material needed for this workshop. http://b-photonics.eu/photonics-toolkit/general-photonics-toolkit
Step 3: Laser Safety
Detail of the laser module in the correct position, see photo 1.
Laser Safety Rules
The laser beam can be dangerous for eyes. Please, follows these rules:
1. Act cautiously and responsibly! Do Not only think of your own safety but also that of others.
2. Never direct the laser beam or its reflection in anyone’s face, including your own. Take precautions and think ahead to ensure that this cannot happen accidentally. Act responsibly!
3. The laser beam should always remain parallel to the table surface and must never leave the table boundaries. Make sure that the beam and its reflections are stopped before they reach the table edge
4. The laser itself, all components in the beam path and beam stoppers have to stand stable.
5. While the laser is on, the space within 10 cm above the table top is the laser zone. The laser beam and its reflections must not leave the laser zone! On the other hand, your eye absolutely must stay out of this zone – that is, in almost all cases, well above it.
6. Before you switch on the laser, ensure that there are no reflective items in the laser zone.
7. If you put anything into, or remove anything from, the laser zone – especially objects in the beam path! – make sure that reflections from their surface are always pointing downwards, towards the table.
8. If you see a laser beam or reflection of a beam on someone: warn him or her.
9. Act responsibly!
Step 4: Realization
Photo 1: Realize the optical kit by laser cutting and engraving of a 5 mm thick plexiglass sheet (about 25 minutes required by a Trotec Speedy 100 Laser Cut machine) according to the project file attached.
Photo 2: Realize the casing by laser cutting and engraving of a 4 mm thick plywood sheet (about 10 minutes required by a Trotec Speedy 100 Laser Cut machine) according to the project file attached.
Photo 3: Remove all the elements from the plexiglass sheet. If necessary, remove the protective film from the plexiglass elements.
Photo 4: Put the desired transparent element(s) on the plywood base, place the laser module close to the base (as illustrated in the figure), switch it on and hit the element with the beam.
To pack away the kit easily:
Photo 5: Place the plexiglass frame on the plywood base.
Photo 6: Insert the transparant elements in the frame.
Photo 7: Cover the frame with the plywood cover.
Photo 8: Fix the package with the two rubber bands.
Step 5: Activities
Use the kit of transparent elements and the laser module to play, experiment and measure light phenomena with a series of hands-on activities. Here there are some examples.
Guess & Try
Photo 1: In this first activity the participants have to respond to a quiz, trying to guess the behavior of the laser beam when encounters different transparent elements. Once answered, the participants can find by themselves the right solutions by experimenting the different conditions (see the figures on the photo).
Guess the laser beam behavior in the following cases of photo 2.
Try & Play
In this second activity the participants can experiment the behavior of a laser beam in different conditions by using many transparent optical elements with different shapes. For example, it is possible to try the following cases:
Photo 3: Reflection and refraction with laser and protractor: point the laser beam, rotate the protractor in different positions and observe the effects.
Photo 4: Refraction in lenses: move the laser beam perpendicularly to the lens length and observe the effect. Try with different lenses, alone or joined together.
Photo 5: "Blend" light with a series of circles:
Play: Challenge other participants: who can use as many disks as possible?
Photo 6: Drive light in a long guide composed by single elements thanks to the total internal reflection (optical fibers principle).
Play: Challenge other participants: who can create the longest guide?
Photo 7: Split light into two (or more) beams.
Scatter the different objects around and hit as many as possible with the laser beam.
Play: Shuffle the transparent elements on the plane and add a target object. Now play to hit the target with the laser beam by using refraction and reflection of light. Challenge other participants. (For example photo 8).
Measure
One of the elements composing the kit is the "protractor", a tool with a graduated scale that allows to study reflection and refraction and to measure incident (α), reflected (β) and refracted (γ) angles in degrees. (Photo 9)
With this element it is possible to estimate the refractive index of plexiglass and verify the Snell law: sin alpha/sin gamma = n2/n1
This can be done in three different ways.
1. Testing the Snell law with the protractor: from air to plexiglass.
First of all, set the system as in the figure in photo 10. The laser beam must:
a) cross the "zero" reference on the right (from the empy part of the protractor, withlight crossing from air to plexiglass);
b) cross the center of the protractor;
c) cross the "zero" references on the left.
Turn a little the protractor, still maintaining the laser beam on the center, and read the three angles on the scale. (Photo 11)
Write the angles on a table:
Incident angle alpha in degrees Reflection angle Beta in degrees Refraction angle gamma in degrees
0 0 0
30° 30° 20°
Repeat the measurement for different rotations (still maintaining the empty part facing the laser) and write the obtained angles on the table. Sometimes it will not be possible to see the reflection; in this case write "NA" (Not Available) on the table for the value of the relative angle.
Verify that angles α and β are equal (reflection).
Report the values of α and γ as points on the following graph photo 12 (the red point plotted corresponds to α = 30°, γ = 20°).
Angles α and γ are linked by the relation (inverse of the Snell law, where n is the refractive index of plexiglass). This relation is plotted in the graph for different values of n. If the Snell law is verified the experimental points from the table must be aligned along one of the plotted curves (or along an intermediate one). The corresponding n gives an estimation of the correct refractive index. In our case the points will be almost aligned on the n = 1.5 curve.
Question: why the points on the graph are scattered?
Answer: Every measurement is subject to an error. In this case there is a big error in the measurement of angles.
2. Testing the Snell law with the protractor: from plexiglass to air
The same measurement can be repeated by placing the empty part of the protractor far from the laser beam (light crossing from plexiglass to air). Photo 13.
Repeat the measurement for different angles and compile a new table:
0 0 0
20° 20° 30°
Put the points on the following graph (the red point corresponds to α = 20°, γ = 30°). Photo 14
Angles α and γ are linked by the relation gamma=arcsin[n.sin(alpha)] (inverse of the Snell law in this case). This relation is plotted in the graph for different values of n. Also in this case, if the Snell law is verified, the experimental points from the table must be aligned along one of the plotted curves (or along an intermediate one). The corresponding n gives a new estimation of the correct refractive index. Once again the points will be aligned on the n = 1.5 curve.
3. Testing the Snell law with the protractor: total reflection
It is also possible to estimate n by considering the total reflection. Rotate the protractor until the refracted beam becomes parallel to the boundary surface (see photo 15). The corresponding incident angle is the limit angle αL.
Since alpha(L)=arcsin(1/n), we can use αL to estimate n=1/sin[alpha(L)]. Obviously the three different estimations must coincide (unless measurement errors).
Extras
We have proposed a series of possible activities with the kit of transparent elements and the laser module, but it is possible to freely explore and create new activities. For example, you can use the kit to invent new games, challenges, puzzles and solitaires; you can measure the focal length of the different lenses, alone or joined together to form more complex lenses; you can create artistic composition with light, and so on.
Use your creativity and enjoy your light kit!
Step 6: End Result and Conclusions
What we learned?
● Reflection and refraction of light
● Speed of light and refractive index
● Snell law
● Total internal reflection
● Working principles of lenses, optical fibers and other optical elements
● Fablabs and their capabilities
Concluding thoughts
In this workshop a technology based on light and photonics (laser cut) is used to practically explore fundamental properties of light such as reflection and refraction and possible applications. This is done with a hands on approach based on a "curiosity driven" and "guess and try" exploration, on games and fun, and also on quantitative measurements. The provided kit (which can be taken home by participants) and the acquired experience can be an inspiration for future original explorations and trials.
ABOUT PHABLABS 4.0 EUROPEAN PROJECT
PHABLABS 4.0 is a European project where two major trends are combined into one powerful and ambitious innovation pathway for digitization of European industry: On the one hand the growing awareness of photonics as an important innovation driver and a key enabling technology towards a better society, and on the other hand the exploding network of vibrant Fab Labs where next-generation practical skills-based learning using KETs is core but where photonics is currently lacking. www.PHABLABS.eu
This workshop was set up by the IFN CNR (Institute for Photonics and Nanotechnologies of the Italian National Research Council) in close collaboration with Fab Lab Milano and Muse Fablab Trento.
