Introduction: Pocket First Aid Kit
About: I'm an artist who using just about anything in my art projects, a type of recycling. I haven't posted in a while because my digital camera died and I'm looking for a replacement.
Out hiking or just for a walk and don't want to carry a bulky kit? This will fit into your pocket no trouble!
The ever so versatile Altoids Tin becomes a First Aid Kit to carry with you. Just add stuff from the following steps (or similar).
Step 1: Stuff to Stuff In
I've addded a few thing sI might find handy, things not everyone will have around.
A suture kit (mine isn't sterile, the package got ripped)
Bands Aids (6 large, 6 small)
Moist Towelettes (optional)
Rubber Bands
Tape
Aspirin
Swabs
Paper Towel (or gauze if you have it)
Razor Blades
Super Glue
Betadine
Isopropyl Alcohol
Step 2: Box Prep
On the back side of the box I put 4 layers of tape. A good storage area and easy to get to.
On the front I trimmed down my Red Cross sticker to fit.
Step 3: Inside Cover
Here I taped the 2 Razor blades and the Aspirin. Easier to get to then digging though the box.
Step 4: 1st Layer
I added the bulky/big things here first. The bottles are must small enough to fit and the suture kit lays nice and flat on the bottom. Be sure to sterilize the suture before use with the Betadine or alcohol.
Step 5: Layer 2
Swabs (ends in little bags) and small band aids fit in here.
Step 6: Layer 3
I added a few small pads of paper towel above the small band aids. If you have gauze use that instead.
Step 7: Layer 4
I folded over the edges of the towelettes to help them fit, these are optional as you have gauze(paper towels) and alcohol.
Step 8: Last Layer
The big old band aids sit on top, make sure you can close up the tin after this step. Rearrange if need be.
Step 9: Final Prep
Close tight and wrap the rubber bands around the case. These can be used for tourniquets or to hold things in place where tape doesn't work.
Step 10: Pocket and Go
All done, now put it in your pocket and go.
Any suggestions are appreciated!
