Introduction: Police Car Soldering Project Kit for Beginners
About: is a global electronics store, which specializes in all kinds of IC products, such DIY Kits, IC accessories, Modules, Robots, Development Board, Transistor, Capacitor and so on. We're located in Shenzhen, Chin…
HE002 is a Red/Blue Automatic Flashing LED Police PCB Car Electronic Soldering DIY Kit. It is powered by 5V voltage from DC-002 interface and automatically flashing and change various lighting effects within Red and Blue LED. Simultaneously simulating the sound of police car horns.
The top of the soldering project kit is equipped with 8 red/blue LED lights. Press the S2 key, you can switch 3 different cool lighting effects, press the S3 key, you can adjust the fast/slow frequency of light flashing, easy to operate.You are free to choose the lighting effect you like.
The icstation police car kit not only allows you to experience the fun of DIY, but also exercises your soldering skills. The process of building a police car from 0 to 1 gives you a sense of accomplishment and a better understanding of electronic components and principles.
If you are looking for a unique creative gift for your son or grandson, this soldered police car kit will be your ideal choice. You can take your son or daughter to solder together, enjoy your unique parent-son learning time.
Step 1: Install 8pcs 220ohm Metal Film Resistor at R1-R8
Install 8pcs 220ohm Metal Film Resistor At R1-R8
Step 2: Install 2pcs 10ohm Metal Film Resistor at R9, R10
Step 3: Install 2pcs 1Kohm Metal Film Resistor at R12, R13 on Another Side of Pcb
Step 4: Install 1pc 2Kohm Metal Film Resistor at R11
Step 5: Install 1pc DO-41 IN5819 Schottky Diode at D9
Step 6: Install 1pc TO-92 S8550 Transistor at Q1
Step 7: Install 1pc 3.5x1.3mm DC-002 Power Socket at DC_5V
Step 8: Install 2pcs 6x6x7mm Black Button at S2,s3
Step 9: Install 1pc SS-12F44 Toggle Switch at S1
Step 10: Install 2pcs 6x6mm Button Cap on Black Button at S2,s3
Step 11: Install 1pc DIP-16 IC Socket at U1
Step 12: Install 1pc 0.1uF 104 Ceramic Capacitor at C4
Step 13: Install 1pc 5V Passive Buzzer at Beep
Step 14: Install 4pcs 5mm Blue LED on the Left and Red LED on the Right
Step 15: Install 1pc DIP-16 IC STC15W204S Controller at U1
Step 16: Connect the DC5V Power. Done!
This Police Car Soldering Kit is perfect for beginners, middle school students, and parents-son time. Learn soldering with fun from ICStation!
