Introduction: Pool Noodle Jewelry Organizer
We gonna be using a pool noodle and reusing empty containers (makeup, cream or anything you like) to create jewelry organizer for you rings and earrings.
You may be able to customize it by coloring the foam using color pencils or
To build up your Jewelry Organizer you will need the following
  • An old pool noodle
  • An empty container
  • All purpose glue
Step 1:
Cut a piece of your pool noodle according to the depth of the container you have.
Step 2:
Place it over the container so you can estimate the area you will need to cut in order to fit your container. You can mark the area you will be cutting with a pencil if necessary.
Step 3:
With a cutting tool - cutter or scissors - make sure you cut according to the area you measured and marked on step 2.
Here you may also style a bit your foam if you wish. You may use color pencils, spray or even glitter to customize it.
Step 4:
Place the cutted piece of pool noodle inside the container and start organizing you jewelry, earrings can be simply pierced onto the foam . For rings you may use a cutter to do an 2-3cm cut on the foam and then place your rings as shown on the picture.
