Introduction: Pot Water Recycler
How to make a 3D printable water recycler for a small clay pot in Fusion 360.
Computer
Mouse
Autodesk Fusion360
3D printer (OPTOINAL)
Step 1: Sketch the Base
Create a circle with a diameter of 177.80 mm.
Step 2: Extrude the Base
Extrude your circle 12.7mm up.
Step 3: Sketch the Inner Circle
Create a smaller circle and center on top of your extrusion with a diameter of 165.10mm.
Step 4: Extrude the Ring
Extrude the ring that the two circles create up 63.50mm.
Step 5: Sketch the Stand
Create four 25.40mm x 12.70mm rectangles on the corners, 90 degrees from each other.
Step 6: Extrude the Stand
Extrude all four rectangles up 25.40mm.
Step 7: Filet (OPTIONAL)
Filet edges as desired.
Step 8: Sketch the Hole
Create a square that is 12.70mm wide.
Step 9: Cut the Hole
Extrude (with cut operation selected) until the hole is cut.
Step 10: Sketch the Spigot
Step 8: Sketch the spigot.
Create a sketch on the bottom of the hole that you just created. Create a rectangle that is 13.208mm x 22mm.
Step 11: Extrude the Spigot
Extrude your rectangle up 14.00mm.
Step 12: Sketch the Channel
Step 10: Make the channel in your spigot
Make a rectangle with the lengths of 12.00mm high x 9.028mm wide.
Step 13: Cut the Channel
Extrude (with cut operation selected) your rectangle to cut the channel into your spigot block.
Step 14: Extrude Channel Again (OPTIONAL)
Extrude the channel even more (20mm) if a longer spigot is desired.
Step 15: Complete!
Your Pot Water Recycler is now complete!
Once printed, you can put a small clay pot inside of it as shown in the render below.
50% scale model used for testing.
Enjoy! 😉
