Introduction: Program Arduino With Phone
In this intractable I will show you how to Program Arduino using your android phone.
I am going to use a female USB to female USB cable because I had two USB extension laying
around so I decided to make this instead of using OTG cable. So basically we will be making
a OTG cable with the micro USB cable and female USB to female USB cable.You can use an
OTG cable Instead if you like. If you decide to us an OTG cable instead you wont need a micro
USB cable.
Step 1: Supplies
Supplies you will need.
1: Smart phone.
2: Arduino. Any Arduino will work just might need different cables.
3: Female USB to female USB Cable.
4:USB Typ A Cable.
5: Micro USB Cable.
Step 2:
Search Arduino Programing app in your device's app
store such as the Google Play Store. Now You will want to tap
on the app that looks like the image above then tap
install once it is installed you will need to launch the
app and then set your arduino app to the right arduino
bored such as Arduino uno.
Tip: If this app docent work with your device
there are other app that will also work.
Step 3:
Connect the cables just like the image above.
Connect the USB type A cable to the USB to USB cable.
Then connect the other side of USB type A cable to your Arduino.
Connect the USB side of the micro usb cable to your USB to USB cable.
Then connect the micro USB cable to your Smart Phone.
