Introduction: Programming the ATtiny
Things You'll Need
- Arduino Uno( Can be done with other boards but I will be using the UNO)
- ATtiny 85 or equivalent
- 10 uF Capacitor
- Jumper wire
- Breadboard
- LED
Step 1: Software
Step 2: Arduino As ISP
Now we need to program the Arduino as an ISP( In-System Programmer). To do this go into the examples and look for ArduinoISP. Open this file and upload the sketch to the UNO as you would with any normal sketch. You have now turned the Arduino into an external programmer. One thing you should check is that you have the right programmer
selected. To do this go to tools and expand the programmer option towards the bottom. Make sure that Arduino as ISP is selected.
Step 3: Hooking Up the ATtiny to the UNO
Next step, attach the ATtiny to the Arduino.
Arduino Pin Attiny Pin
10 to 1
11 to 5
12 to 6
13 to 7
5v to 8
GND to 4
*note: See pictures for pin configuration of the tiny
Now you need to put the 10uF capacitor between the reset and GND. Be sure to observe polarity( the small negative signs go to ground).
If you don't put the cap in there it won't work.
Step 4: Program the ATtiny
You are now ready to program the ATtiny, but first we need to select our ATtiny chip. To do this, go to "tools" click on "boards" and select the the ATtiny 85 with 1MHz internal oscillator. Don't use any of the ones that say external oscillator because you need to hookup a external crystal of the frequency. We should check to make sure everything has worked. Go into the examples and open the "blink" sketch change the line "int led = 13"; to "int led = 0". Now, in order for the sketch to upload you need to go to "file" and click "upload using programmer" it will start uploading and you will get 2 errors that say "avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny85" this tells you that the ATtiny has successfully been programmed. Plug in a LED to pin 5(labeled as pin 0) and connect the negative side to pin 4(GND). It should start blinking at 1Hz. Have fun building and creating with your new tinier arduino.
Some things to note about the ATtiny. It doesn't support all the functions that the UNO does but it does support the following:
- pinMode()
- digitalWrite()
- digitalRead()
- analogRead()
- analogWrite()
- shiftOut()
- pulseIn()
- millis()
- micros()
- delay()
- delayMicroseconds()
- SoftwareSerial
*Another Note: To run the board at 8MHz you must burn the bootloader. To do this, Click on ATtiny 85 with the 8MHz internal oscillator. Click on "tools" and click on burn bootloader. Once that is done the Attiny will run at 8MHz. Doing this will give better timing.
