Introduction: Project BOX K'nex Ball Machine
My smallest Ball Machine to date. Also, this is my final tiny ball machine. From now on, I go bigger (no pun intended).
Pieces:
Red Rods: 3
Yellow Rods: 20
Blue Rods: 197
White Rods: 58
Green Rods: 100
Blue 3D Connectors:20
Purple 3D Connectors: 103
White 8-Slot Connectors: 39
Yellow 5-Slot Connectors: 56
Green 4-Slot Connectors: 6
Red 3-Slot Connectors: 19
Orange 2-Slot Connectors: 7
Gray 2-Slot Connectors: 1
Gray 1-Slot Connectors: 9
Tan/Brown/Orange Tabbed Connectors: 2
Motors: 1
Balls: 1
Blue Bearings: 7
Silver Bearings: 5
Gears: 4 Red
Chain Links: 35
Black Y Connectors: 2
Total: 695 Pieces
Pieces:
Red Rods: 3
Yellow Rods: 20
Blue Rods: 197
White Rods: 58
Green Rods: 100
Motors: 1
Balls: 1
Blue Bearings: 7
Silver Bearings: 5
Gears: 4 Red
Chain Links: 35
Total: 695 Pieces
Step 1: The Center Frame
This is where the lift will be located.
Step 2: The Wheel Side
This side will hold the wheel later on.
Step 3: The Other Side
This side will hold the other stuff.
Step 4: The Top Gear
This part will support the chain.
Step 5: Mini Thisorthat
This part decides where the ball goes.
Step 6: The Micro Ramp
This leads to the Wheel.
Step 7: The Wheel
This part spins. Build, take out a blue rod, then put in the Wheel. Replace blue rod.
Step 8: The Ramps
These two make the ball drop.
Step 9: The Chain
This part has 35 Black chain links.
Step 10: Usage
Fix this part.
Add ball, Turn on.
Add ball, Turn on.
