Introduction: Project Robot Bug - With Wii Nunchuck
Project Robot Bug
What the robot must have:
Moving object, led licht
The robot material must consist of 3 different types of material
3D printers are required in the process of making this project .
Step 1: Project Parts & Assembly Steps
list of parts needed for this project
- Arduino uno or another version of the arduino family
- breadboard
- wii nunchuck
- laptop
- connector wires
- led lichts
- 2 servo's
- material for 3D printing
- 9volt power supply battery
Step 2:
the nunchuck has 4 wires coming out
yellow - this is the data wire that goes to the pin number A5
green - this is the data wire that goes to pin number A4
red - this is the power 3.3v wire
white - this is the ground wire
attach these wires to the arduino uno
then attach the mini servo's to the arduino
the mini servo has 3 wires
oranje goes to digital pin 12 or 7 ( depends on where it is stated in the sketch for the output to be) in my sketch it is at pin 12 and pin 7 for 2 mini servo's
red - power 3.3 v
brown - ground wire
pin 13 is for a led licht and this works with the Z button on the nunchuck
pin 8 is also for a led licht and works with the c button on the nunchuck
when you have everything attached you can upload the sketch en have fun with this project
Step 3: Wii Nunchuck Sketch for Arduino
wii nunchuck sketch for arduino uno
include's 2 servo's and 2 led lichts
libraries contains ArduinoNunchuck .ccp and .h files
sketch_apr02.ino is ready to use in your arduino
Step 4: 3D Printing En Laser Cutting the Casing for the BUG
Here I 3D printed a wheel base for my robot bug
After that I went and laser cut a casing for the arduino
For the last step I assembled the robot together with the servo's and a led light on top
of it like a really creepy bug .
I have algo attached the file for the 3D printed wheel and the laser cutted casing for the arduino uno.
Step 5: Prototype Test
the end result and test will be uploaded on 07/04/2016
