Introduction: Pumpkin BBQ
Good morning, evening or afternoon.
And welcome to this instructable on how to make a 3d model of a pumpkin barbeque in 123d design, which you can download here- http://www.123dapp.com/design .
This is a great barbeque for Halloween, as you can roast marshmallows through the mouth, nose and eye hole. Put the top on, and the smoke will pour out of the holes making it look very scary and spooky.
Don't forget to vote for this instructable if you like it.
The pumpkin from this is made by fungus amungus and can be found here- https://www.instructables.com/id/3D-printed-Jack-o-Lantern/
Step 1: Starting Off
To start off download fungus amungus's pumpkin model or make your own in 123d design.
Now place a cube the same size as the pumpkin and draw a thin rectangle about 3/4 of the way up.
Finally extrude the rectangle all the way through the pumpkin, then delete the remaining square and move the lid over.
Step 2: The Stand
To make the stand firstly place a cylinder in the middle of the bottom of the pumpkin.
Then pull it outwards to increase the size a little and next pull the bottom of cylinder downward to your desired size.
Now combine the two together.
Next draw a circle on the bottom of the cylinder and pull downwards slightly.
Finally to make the shelf place a cube, draw a rectangle on it and extrude it half way.
Step 3:
To create a face on the pumpkin place a square the same size as the pumpkin.
Next draw your desired design on the front face of the cube and finally extrude the design through the front of the pumpkin.
