Introduction: Pumpkin Floam Butter Slime!
What you will need:
-White School Glue (I used Elmers)
-Lotion (I used Jergens)
-Sta-Flo
-Orange Food Dye or paint
-Orange, White, and yellow foam beads
-Charm! (Optional)
-Orange or white (but you would have to color it) Model Magic
Step 1: Add Your Glue
I added 1 cup of Elmers White School Glue.
Step 2: Add Your Lotion
I added 5 squirts of Jergens Lotion. You can use any lotion but it can not be Petroleum Jelly.
Step 3: Add Your Food Dye
I added 2 squirts of my orange food dye. Paint works as well.
Step 4: Activate!
Activate your Slime! I added 3 seconds worth of activator at a slow steady rate. But keep adding your activator until your slime does not stick to you, does not stick to the bowl and you like the consistency of the slime. If your slime is hard add more lotion, if it is still sticky add more activator until you like it.
Step 5: Scent! (Optional)
I had a candy Corn scent on hand so I decided to use it! If you have a scent use 3 drops of it and then knead it in with your hands.
Step 6: Add Your Model Magic
I added about an inch in diameter of model magic. Here are the types of clay I recommend for slime:
-Daiso Soft Clay
-Crayola Model Magic
-any type of clay that says βslime clayβ
Then just mix your slime clay into your slime until it is fully kneaded in. DO NOT USE SHAPING CLAY OR HARD CLAY THAT YOU HEAT UP JN AN OVEN IN SLIME. IT WILL RUIN IT. Also using Play-doh in slime is difficult it melts the slime immediate but if you add the play-doh and activator in the slime at the same time it will be ok! :)
Step 7: Add Your Floam and Your Charm!
I used about 1/8 a cup of Floam beads. Just shake your foam beads into the slime and knead/mix it in! Do not pick the Floam up with your hands. The Floam has static electricity and will stick to you. It can not hurt you! :) For the charm you can purchase them from a craft store or online OR you can even D.I.Y. IT! My friend @parakeetcrafter (go follow them! They have THE BEST crafts and instructions!) actually made this for me with flour and water! Comment if you would like me or @parakeetcrafter to make an instuctable on how to make a D.I.Y. Charm! So just place the charm on the slime.
Step 8: You Are Done!
I hope you liked this craft! Comment some ideas for me to do! Also check my last instructable to find out how to make the Slime candy corn showed above! That is also a very fun craft! But good luck to everyone in the pumpkin Competition! π π» π§‘ππ€π§‘π€π€
