Introduction: Pumpkin Safe.
I made this for the "Jack o' Lantern Challenge." it is a safe (Do not use as an actual safe). It does not need any external parts to function. in the following steps i will show you how it works.
Step 1:
First you must slide the main rod in to the base via the notches this allows the freedom to spin.
Step 2:
Next turn it 90 degrees and slide the top part of the pumpkin over and make sure that the top part is aligned with the bottom.
Step 3:
Finished! Spin the root to open it.
