Introduction: Qatar 2022 Argentina Champions
During November as we all know the 2022 Qatar world cup took place. During that whole time I was supporting Argentina especially because of Lionel Messi, growing up I heard great story's about him, but he was never truly respected because he didn't win a world cup. So this was his last dance, and I knew this would be my last time to watch him in a World Cup. When the final took place and Argentina won I was so happy for him and I knew he accomplished his childhood dream.
Anyways, this inspired me to create a little memory for me so I would never forget when Argentina won the world cup.
Wood piece
Wire
Hot glue gun
LED lights
Battery
battery pack
Drill
Solder
Laser engraver
Step 1: Engrave World Cup on the Piece of Wood
With your laser engraver you type in "Qatar World Cup 2022 World Champions Argentina", and let the machine do the work.
Step 2: Drill in Your Holes in the Wood
Drill your holes in 4 corners(or more).
Step 3: Begin Soldering Your LED
With the wire you have cut 8 pieces(It will help you if you do red for positive and black for negative). After that you will snip the the top of the wire you can solder that. Do that with every 8 pieces, then you will want to solder the red wire to the positive side of the LED and the black to the negative one. You will repeat that process 4 times.
Step 4: Put LED's in the Wood
Insert the LED's in where you drilled in the holes. After, that hot glue your LED's so they stay.
Step 5: Connect Every Negative and Positive
Now you want connect every negative with a negative, and every positive with a positive.
Step 6: Add the Battery
This is the last step, when you have the battery pack get a red and black wire and solder it to the battery. Then connect the red wire to a red and a black to a black, and your all set.
