Quick and Easy Bow and Arrow!
Intro: Quick and Easy Bow and Arrow!
All you will need for this is some 1/2 inch pvc pipe ( 1/2 inch diameter of hole in the middle)
STEP 1: the Materials!
All you need is-
-a saw
-some string
-1/2 pvc pipe
-a saw
-some string
-1/2 pvc pipe
STEP 2: How Long Should Your Bow Be?
Your bow should be the as long as your arm span.
STEP 3: Where the String Goes
On the ends of the pipe you can cut a V shape cut 2 inches from each end.
STEP 4: Now for the Length of the String. and Tying
The length of the string should be 4 inches shorter than the bow. For the tying string you should make a loop knot and put the string through the loop.
STEP 5: Final Step!
Now bend the pipe so you can loop the other end of the string on the the other V shape cut. The bow should be fairly bend like the picture below
STEP 6: And Your Done!
And all you have to do is get a straight stick or buy a wooden dowel, sharpen then fire
Note the bow is a weaker than other wood bows but is still strong.
77 Comments
useful_things 11 years ago
avenger22 11 years ago
ThePyroManiac 17 years ago
oldmanbeefjerky 11 years ago
LiftAndLove 13 years ago
meritsetgo 15 years ago
knexlegowizard101 14 years ago
khaedo 14 years ago
greymatter21 14 years ago
totjup2 15 years ago
huntingfisherman 15 years ago
Kendallkip 16 years ago
ninjallama 16 years ago
hunteo 16 years ago
jman64 17 years ago
rolthox the real rolthox 17 years ago
texabyte 16 years ago
juaniskool 16 years ago
jjy 16 years ago
